mildkiller
May 14, 2014Explorer
URGENT! Rockwood 2318G doesn't have any signal lights on
Hi gurus,
I have a one year new tent trailer Rockwood 2318G. It's been functioning perfectly last year. Yesterday I pulled it out from an indoor storage and realized two things:
1. The battery was drained because I forgot to remove it. Now it's been recharging.
2. All signal lights don't work except the left side break light.
Symptom: when step down the break, only the left side break light is on, the right one is not. try the left and right turn signal, no light on. try the evening running light, no light on. the electric break controller has a green light that should indicate the connection is ready. it's off too. So I had to tow the trailer back without electric break and turn signal...
I check the 7pin plug diagram but still can't determine the issue is on the vehicle or the trailer. Anyone can help with step-by-step instruction? I have a volt meter. How can I test the 7pin plug on my Odyssey? For example, when give out the left turn signal, how much voltage can be read on the plug? The tow package, electric break and all wiring were installed at U-Haul and no issue last year. Really have no idea why it suddenly has an issue without any change on both vehicle and trailer.
Thank you for help!
Daniel
Thank you for help!
Daniel
