Freeway Flyer 05 wrote:
It is a 25RS, I can't find the year, but I think it was about 10 or 12 yrs old.
It must be a 25R. There never was a model called a 25RS. Northwood doesn't use two letters in their model numbers, except on some of their toy haulers.
Also, Do you have a link to an online ad?
2002 25R is listed at 5720 dry weight, 640 hitch weight
2008 is 5780/600
My parents currently own a 2014 25R. This is their second 25R.
They tow it with a 2006 2500HD Duramax.- Freeway_Flyer_0Explorer
ScottG wrote:
Just like any other brand, look for evidence of past leaks in roof and soft spots in the floors and avoid if either are found (even if they claim it was "fixed"). Other than that, they were built better back then and I think she'll be happy with it.
Thanks. - Freeway_Flyer_0Explorer
Thanks, I will make sure to run it across the scale, I have been surprised before with how heavy a trailer can be.
Which model Arctic Fox is it?
I have a lot of old AF brochures and can look at the weight, if the brochures I have list that model.
Roof is the most important thing to look at, and look at it closely.
Figure on it needing new tires and the bearings repacked, unless the owner has put new tires on it within the last 2 -3 years and has receipts showing a bearing re-pack.
However, we have a hitch in the giddy-up. My daughters employment is seriously affected by the local school shutdown, as in contract employee, no work, no pay. Hopefully, it will still be available when she is back in business. Thanks for checking. - ScottGNomadJust like any other brand, look for evidence of past leaks in roof and soft spots in the floors and avoid if either are found (even if they claim it was "fixed"). Other than that, they were built better back then and I think she'll be happy with it.
Figure on it needing new tires and the bearings repacked, unless the owner has put new tires on it within the last 2 -3 years and has receipts showing a bearing re-pack.- Freeway_Flyer_0Explorer
ppine wrote:
The weight needs to be looked at carefully.
I had a Nash trailer that was stick and tin and I sold it only because it was really heavy.
check for water damage.
Thanks, I will make sure to run it across the scale, I have been surprised before with how heavy a trailer can be. - Freeway_Flyer_0Explorer
Westcoasting wrote:
She sent me the VIN, I looked it up, well within the limits of her truck.
Where is this "VIN lookup" place that tells you an RV is "within the limits" of a given tow vehicle?
I've never heard of a website offering that kind of a database.
Probably the same website that says you don't need a wd hitch!!
Thanks, really appreciate your well reasoned input. - Freeway_Flyer_0Explorer
Not hard to find, just use that thing called Google, whatever VIN decoder you use basically gives you the exact specifications for that particular vehicle. The GVWR, the CGVWR, the axle GWR, the rear end ratio, the transmission and engine combination. Then head over to Trailer Life Tow Vehicle ratings, and look up the truck. I know the weight of the trailer, factor in the water, propane, and other misc. equipment, and I know that the combination will work or not. Sorry I didn't take the time to explain all that the first time, I've only been doing this trailer stuff for about 35 years or so. - ppineExplorer IIIThe weight needs to be looked at carefully.
check for water damage. - WestcoastingExplorer
44,065 PostsLatest Activity: Apr 14, 2026
