Welcome to the forum Hanklee. I don't think your truck will be a problem.
Tires on the trailer and getting the trailer level when hooked to the truck seem to be your major concern. Are you leaving the trailer on the property or towing it back and forth when you want to use it?
Reason I ask is the level of repairs needed will vary depending on what you are doing with it. If you are planning to drag it there once and leave it I would look for a spare tire or two and take my time pulling it there on back roads avoiding highway speeds.
If you are running it back and forth then new tires are a must.
