CharlesinGA
May 14, 2020Explorer
colliehauler wrote:Mike134 wrote:This ^^^
There is a pawl that needs to disengage the motor on mine if I use the hand crank, likely yours is stuck open or broken
^^^ THIS...........
When you insert the crank, it disconnects the motor drive, and when you remove the crank, it should spring back up and reconnect. Could be a spring is rusted and broken, could be that it is simply stuck. Put the crank back in and wiggle it around and use lots of spray lube on it. It may need replacing, but it also may just need a little TLC from lack of use.
Charles
44,065 PostsLatest Activity: Apr 14, 2026
