- APTExplorerTow/Haul lock out 6th gear is what I recommend and do with my similar power and weight combo.
- Regardless of the engine or even the gear ratio, if the trans shifts in and out of 6th to 5th a lot, I lock out 6th.. Depends on the road, wind, speed limit, etc..
And I've got the EB and 3.73 gears and only towing a #5000 TT...
I did the same thing with my old 97 F150 towing the same TT and locking or not locking out OD (E4OD trans).
So, as I said, for me, it just depends... ;)
Mitch - baitboyExplorer6200 lb. TT, 26 1/2 ft long. This is my loaded weight.
- rhagfoExplorer IIIWhat are you towing and how much weight?
- baitboyExplorerI have the 5L V8, 3.73 rear end with the tow package. Hope that helps.
- trop-a-calExplorerWhat engine?
44,056 PostsLatest Activity: Dec 27, 2025
