Reddog1
Jan 23, 2015Explorer II
I have had mine since about 2005. I installed it myself, with no help. I replace hydraulic jacks with the Stable Lift. In times past, I posted several posts and provided several photos to dispel the myth it only worked on "either on grass or gravel or a smooth service".
For me, upgrading from hydraulic to Stable Lift is the only way to go. If I already had electric jacks I don't know if I would spend the money. Do I think the Stable Lift is better than four separate jack, yes.For real serious off road, it is questionable for many folks. You will loose about 2" of ground clearance if it is setup properly.
I can, and have written a lot on the Stable Lift. If you search, be sure to go to Advanced, and then in the Date Posted go to Archive.
Wayne
Wayne
44,068 PostsLatest Activity: Jun 21, 2026
