jmacpolo's avatar
jmacpolo
V-10 problems
I started out years ago towing our 7,000 lb trailer with my old chevy 2500 with the 350. I tow mostly in the Sierra and Rocky Mts. I hated the way I had to slow down to 45 mph going up the grades. So after reading what others had said about them, I bought a 2007 Ford 3500 V-10. I have been very disappointed with the power of the V-10. Now I can hold 50-55 mph while going up grades. I thought the v-10 would give better performance than that. Am I expecting too much from this motor, or is there a problem with my V-10?
Thanks,
John
  • Are you pushing the gas pedal the way?
    Have you checked basic maintenance items like the air filter?
    My trailer is 12,000 pounds and and I pull 6% grades at 62 MPH.
  • I doubt it's a "problem" then the engine. Your engine computer would be lighting the "check engine" light if there was.
    More likely it's an issue with the rear-end, as in the wrong ratio. Do you know what it is?
    With my ol trailer (about that weight) I had no problems with 60 mph on most grades. With the new (heavier) trailer (13,000) 60 can mean winding the engine to 4500 rpm (or higher)
