carringb
Aug 20, 2020Explorer
What year? Based on your symptoms, you must have a 2005 or newer?
Sounds suspiciously like a faulty electronic throttle body / MAF assembly.
You most certainly should get it properly diagnosed. A new engine and transmission wont' fix this problem if its the throttle body assembly. And will easily cost many thousands, vs a couple hundred for a new TB.
Are you sure you have a 4R100? Because that trans doesn't have Tow/Haul mode.
