Grit_dog
Aug 21, 2020Trailblazer
Groover wrote:dodge guy wrote:
I'm going with a fuel pump failing. Your losing fuel pressure. When that happens you can get the symptoms you describe!
That or trash blocking the fuel intake. When you shut down the trash may float away, restoring flow and power. But, it will be back!
No, not likely at all. Bad fuel pumps, I cannot think of a case where it's in intermittent issue, like the OP is experiencing.
