hdbroker
Aug 22, 2020Explorer
carringb wrote:
What I would consider replacing on a preventative basis is the upper radiator hose, and the heater hose that comes out of the intake. These both take most of the heat, so they get weak first. Also check the hard lines going to the rear HVAC. These can corrode in salt states.
Yep, I have a slow HVAC leak someplace that nobody seems to be able to find.
I have run Mobil 1 in every vehicle I have ever owned and never ever burned a drop of oil. I have a focus with 230k miles and still does not burn oil and runs like the day I bought it. This V10 burns half a quart between oil changes and it drives me nuts. Previous owner probably used Jiffy Lube oil. I flushed the transmission when I bought it and switched that over to Mobil 1 ATF as well. Did the transfer case and rear Diff also.
