babock
Nov 09, 2017Explorer
Grit dog wrote:Assume you meany "buy". The hardware kits are anywhere from $6 to $15 per axle. It's typically the slides that the pads ride on, anti rattle clips, small pieces that help hold the pad away from the rotor and possibly slide pin boots.
but new hardware,
It does not surprise me that you aren't replacing these. Just pointing it out to the others that don't want to do a half aZZ job as another poster mentioned.
As far as rebuilding calipers, I would never rebuild a caliper even if it has failed. OEM new calipers are not that expensive and they last a LONG time.
