1969SSCamaro's avatar
1969SSCamaro
1995 P32 Rotors Overheating
I have a 1995 Georgie Boy Pursuit, 27', 454 TBI with front disc and rear drum brakes. Purchased the rig about 1 year ago and did a complete front end brake job: turned rotors, new ceramic pads, repack bearings, new rubber brake lines, new master cylinder, fluid flush, etc. I also meticulously cleaned all of the moving caliper parts with wire brush (using drill attachment) and applied grease (although I should have purchased extra as they don't give you much with the new pads). Since that time I have taken it out on several short trips and one longer trip (~500 miles round trip), but for the past 4-5 months it has been sitting in the driveaway. I try to drive it to work every 4-6 weeks when not using it. Last week I drove it to work and noticed a burning smell, which turned out to be the brakes. I measured the rotor temps at ~440 deg F -both sides; happend in the morning drive to work and the evening drive home. I drove it again to/from work about 3 days later and it was fine; rotor temps were ~ 240 degrees - both sides.
I have studied forums and two main causes appear to be bad rubber brake lines (swelling/pinched) or sticking calipers, but I supposedly took care of that with new hoses and brake job. The problem is evidently intermittent and the one time it did happen, both sides exhibited the same problem. Is it common for both sides to stick like that and/or could that help with diagnosing the problem?
Thanks for any/all suggestions.
