Atlee
Nov 10, 2017Explorer II
Everything I have read says ceramic is not the pad to use if severe duty is in the forecast, and for me it definitely is.
What I've read says ceramic does not dissipate heat nearly as well as the semi-metallic.
The good qualities of the ceramic, easy on rotors and less dust do not out weight the good qualities of semi-metallic, which is greater heat resistance and designed for severe duty, which a month rummaging around the Rockies will be.
mt1729 wrote:
Ceramic pads.
