wmoses
Jun 16, 2014Explorer
Gsragtop wrote:
My new unit has a wall mounted AC unit and while we were doing the walk around, it was running. The water was dripping out the back like it should, and all was dry inside when we left.. However when we got home there was water on the table and floor below the unit.
So my question is how do I prevent this ?? I was thinking of tilting the trailer a little while parked...
When you saw it during the walk-around, was it tilted? If not then you likely do not have a problem.
Could it be that the water that ended up on the table and the floor was due to the movement of the trailer as it was towed home after the walk around? In other words some of the water that was entrained in the AC unit made it out due to motion-indcued sloshing.
You did not mention (a) timeline, (b) whether the AC unit was running just before you towed the RV home, and (c) how much water is on the table and floor.
44,056 PostsLatest Activity: May 04, 2014
