beemerphile1
Jun 16, 2014Explorer
Modern window shaker units hold condensate (water) inside to increase efficiency. There should be a drain plug on the outside. Either drain before moving or leave the plug out.
I modded mine so it holds enough water for the slinger to pick up but not so much as to slop inside. I removed the plug and installed a rubber grommet so it is still open but retains some water.
44,056 PostsLatest Activity: May 04, 2014
