kcgaz's avatar
kcgaz
Warm Fridge - Dometic DM2882
My Dometic DM2882 has an ice cold freezer, but the fridge goes from low 40's to 60 as the day heats up. Does anyone know if this refrigerator has electric fans on the backside below the coils? I can't see any, but its pretty tight in the compartment. I'm thinking this could be an air circulation problem, but would appreciate any advice and guidance. Thanks in advance for your help!
Best,
Kevin
  • Typical in hot weather. Adding a fan that clips onto the fins inside the fridge helps.
    Adding fans to the "chimney" also helps. My twin fans for the chimney are on a mechanical thermostat.
