JBarca
Nov 29, 2014Nomad II
Hi, Your saga happens... Not a lot, but it happens more then we think. And it happened to me too. I'll comment in blue
There is not an adjustable adjustment on most campers that can be made to fix trailer alignment. The hangers are suppose to be welded in the correct place which sets the thrust angle. The axle tubes are suppose to have the correct camber and toe bent into this on day one. When they assemble the right parts to the correct hangers, alignments comes out OK.
That said he could of checked the alignment after the hanger move. They may have a portable setup or they can put it on a machine.
If you want to press for something, request an alignment report be part of the repair. Or take it to a truck spring shop as they often have a machine they can put the camper on to get an alignment report. Armed with an alignment report you now have proof the running gear is correct or not. If it is off, it will wear tires again. If it is right it will be OK. This report very soon after the repair can be used with the TT manufacture if it does not came out right, they still have work to do.
They may or may not pay for the worn tires under warranty. A hanger being welded on wrong can only happen at the factory. If an axle is bent, it can be argued you caused it and they do not warrant alignment. We have heard this all too often.
If you are into the tech stuff of trailer alignment, see my saga. I had hangers welded on wrong and both axles made wrong to toe anlge. I replaced both axle tubes and installed adjustable axles seats. I now can adjust thrust angle on my camper. Camber and toe angle is still not adjustable other then physically bending the axles which is done by some alignment places.
TT axle alignment & install - Detailed (long lot's of pics)
Hope this helps and good luck
John
likesadvice wrote:
I'd noticed one tire was wearing poorly, but attributed this to the manufacturer putting on cheap bias ply tires. During the trip tires started burning off the TT. I never had a blow out, but the tires were very close, wearing on different edges. Were all 4 tires showing odd wear? or just the 2 tires on the same axle they moved the spring hanger on? Which tires were wearing and which spring hanger did he move?
During the trip I shelled out $420 for 5 new radial tires and spent most of the 2200 miles driving white knuckled. If you are still white knuckling it after the fix, this may be a different problem and need to help get that fixed too.
In September I pulled the TT to my dealer for warranty repair.
A leaf spring hanger was installed in the wrong place, making the spring hangers 2" out of square and thus an axle wasn't square with the camper. The repair technician welded a new spring hanger in the correct position and said the repair was complete. Again, was it only 1 hanger he moved? Or more? front axle or rear axle?
I have submitted a request for reimbursement for the tires and a 1 year extension of the frame warranty to make certain I don't have further issues. My question is - Should I be requesting more? If they actually give you a 1 year extension on the running gear, running gear meaning the axles, springs, hangers, shackles and equalizer, then that is an undertaking all by itself. Curious on how this comes out.
Shouldn't the manufacturer have replaced some axle components, bushings and bearings after the TT was pulled nearly 3000 miles in total since manufacture? They should of done an inspection to see if the severe scrub angle damaged anything else. If the inspection came out OK, then they would not need to replace. 3,000 miles is not really a lot of miles.
Should the technician have aligned the axles after installing a new spring hanger? The service manager told me he was surprised how fast the technician was in and out. Any advice is greatly appreciated.
John
