JimK-NY's avatar
JimK-NY
Explorer II
Jun 14, 2015
Water damage from an overlooked source
Check your Happijac electrical connection boxes!
I have been meticulous in maintaining my Northstar Igloo. I have spent many hours removing old but perfectly good caulk and replacing it with fresh Geocel or Dicor caulk. Even so, I had a very unpleasant surprise a few days ago. I was checking my generator compartment and found wet, spongy, rotten wood. It was a sickening feeling, especially because the source and extent of the damage were not clear. Fortunately I was lucky and the damage was restricted to the area of the generator compartment. The wood in the corner was entirely rotted out from about 2" below the top of the compartment to the bottom. A side rail at the bottom of the compartment was rotted out from the corner until almost the end of the compartment.
I had to remove lots of screws including the screws from the bottom of the Happijac support bracket. I spent hours slowly removing the damaged wood with a chisel. I worked slowly to the skin of the camper without damaging it. Along the way I encountered lots of additional screws and staples. I evened the remaining wood with Bondo and fit new wood in place with Bondo behind it.
Because of the way the rot spread it was initially difficult to determine the source. The water appears to have come from the Happijac electrical connection. For the back two jacks, Northstar installed the boxes upside down. Instead of having the wires from the jacks come into the bottom of the boxes, the wires inserted on the top. With time the plastic connection box on the right side cracked. Water ran down the wire into the connection box. The water entered the camper through a 3/8 inch hole where the wires enter the camper. With time the rot spread upwards about 4", traveled down about 10" to the bottom of the compartment and then rotted 10" of the adjacent horizontal wood at the bottom of the compartment. It is hard to believe a slight cracked resulted in that much damage. The leak must have started months or possibly years ago.
  • I don't have wood but never thought of looking there for a water leak. Thanks for the post. I HATE WATER LEAKS IN CAMPERS!!!!!!!
  • I have a 2016 Northstar Adventurer 8.5 with the removable wrap, the bottoms of the compartment is bare wood. I am a hobbyist boat builder and plan to coat the interior of the aft compartments with a coat of epoxy, hope that will help preserve the wood in the compartments. As a boatbuilder I am impressed with the quality of wood in my Northstar!
  • I also have a Northstar. Mine is an 8.5 Arrow.
    I looked at the wire entry box for my happy jacks and the wires also enter from the top.
    It does seem like it's upside down.
    I will reseal immediately. Thanks for bringing this to my attention!
    It is amazing how much of the human race does not understand that water runs downhill. this seems to include many home builders and roofers - and I guess RV builders too. At least you caught it when it was still reparable.
  • I don't know the age of your Igloo, but you have described this situation so well, have you considered contacting Northstar with your findings. Maybe they can change the way it's designed.
  • Sorry to hear of your water damage JimK. It is especially disheartening when one works so hard to prevent such damage. Sometimes it seems that water is just determined to breach all barriers and invade our campers. It would be easy to miss the electric jack connectors and it sure doesn't help when it is installed with the wire entry on top. Just want to add to also check the seal on the jack brackets. I recently removed one to fix some damage and was surprised to see the only water barrier was the thin bead of sealant around the outside of the bracket. There was some sealant randomly applied between the bracket and the camper but not in any manner to divert water away from the screws or to prevent it from migrating along the screws into the camper. Now I want to do the other three.
  • Thanks for the info, I have Atwood jacks but I will check the plugs. Another thing I always check are the outside storage doors, you have to lock them to get a good seal.
  • Ugh.
    I know that sickening feeling. You work hard to keep anything from leaking with tons of preventative maint. and keeping an eye on every detail.
    Then some sneaky leak pops up where you never expected it :M:M:M
    Good luck on the repair -hope it's easy enough.
