bluearc's avatar
bluearc
water heater connections
Can someone describe this type of connection and how it comes apart.
thanks
  • Suprising-though never looked
    online shows it at HD/lowes if you have the sharkbite tools, ring also needed. Assuming line end
    http://www.homedepot.com/p/1-2-in-Brass-PEX-Barb-x-1-2-in-Female-Swivel-90-Degree-Elbow-UC532LFA/202270585
    https://www.lowes.com/pd/SharkBite-1-2-in-dia-Brass-PEX-Adapter-Elbow-Crimp-Fitting/1000182985
    https://www.amazon.com/SharkBite-UC532LFA-Swivel-Elbow-2-Inch/dp/B007AHJA1Q
    push to connect brass
    http://www.pexuniverse.com/1-2-x-1-2-fnpt-swivel-elbow-push-fitting
    Flair-it also makes compression ells
    https://www.amazon.com/gp/product/B000BQSUX2/ref=s9_acsd_hps_bw_c_x_2_w
  • I went to a few places like HD and Lws but could not find a matched a fitting, I need the swivel 90 going in the tank.
  • Similar to ours.
    Ours and most use a swivel connection that threads onto water tank. Ive seen pictures of fittings without swivel that were threaded onto tank and then lines crimped on-
    hopefully yours isn't one of those- a bit more involved.
  • bluearc wrote:
    Im having trouble posting pictures of the tank.
    Just go to THIS SITE and drag n' drop the file (or browse to it) and then copy and paste the resulting string into your reply text wordage.
  • Im having trouble posting pictures of the tank. The fitting is located behind the hot water tank, it is a 90deg into the tank.
    I tried this below, but got discouraged about half way through.
    Profile and Signature Pictures (RVSnowbird)
    Posting pictures within text messages (RVSnowbird)
    Signatures
    How to place a picture in your signature (pulsar)
    Size requirements - where and how to upload picture.
    I get an error message when I attempt to upload a picture to my signature (pulsar)
    General cause of the error and what to do about it.
    Post your signature picture here (RVSnowbird)
    Show off your signature picture here.
    Resized, Panorama and multiple picture signatures (RVSnowbird)
    Using irFanView to resize and/or combine pictures
    Make your own signature license plate (RVSnowbird)
    Using Win-XP to resize photos for your "Signature" (RVForever)
    What program are most using to resize for signature (joeneal)
    Add a Visited States Map to your signature (egrove)
    How to make a US, Canadian or Mexican map and upload it to your signature.
    Combining signature maps using MS Paint (RVSnowbird)
    Can't see pictures because of preferences - tutorial (pulsar)
    Where and how to change this preference setting
    Posting pictures in text
    Screen resolution for pictures in text (RVSnowbird)
    Posting Pictures Using TinyPic.Com For The Host Site (pulsar)
    Tutorial with pictures - Uploading to TinyPic.Com, Selecting the correct URL, using the Image tool, resizing, if necessary. No account required.
    Posting Pictures Using PhotoBucket.Com For The Host Site (pulsar)
    Tutorial with pictures - Uploading to PhotoBucket.Com, Selecting the correct URL, using the Image tool, resizing, if necessary. Assumes that pictures are already in Photobucket.Com web album
    Posting Pictures Using Picasa For The Host Site (pulsar)
    Tutorial with pictures - Assumes that pictures are already in a Picasa web album
    Posting Pictures Using Imgur For The Host Site (1492)
    Video tutorial. No account required.
    Click to enlarge pictures within text (RVSnowbird)
    Advanced technique. Shows how to insert a normal size picture that will enlarge, when clicked on.
    Embedding a link within a picture (RVSnowbird)
    Picture Hosting? (before posting a picture within text, it must first be on a host website)
    Picture Host Information (RVSnowbird)
    Alternate Quick Picture Hosts (RVSnowbird)
    Other:
    Alternate "portals" to the RV.net Open Roads Forums (RVSnowbird)
    There are several ways to enter the Open Roads Forum. If you are having trouble with one, you may have more luck with another one.
    How is membership "status" determined? (pulsar)
    Why am I still a new member? Or how do I become a senior member?
    Displaying the Good Sam logo (pulsar)
    How to display or turnoff the display of the Good Sam Club logo seen at the left side of many forum members's posts.
    10 tips to posting in the RV.Net/Forums (RVSnowbird)
    10 reasons for a red X instead of a picture (RVSnowbird)
    Using the message toolbar and 4UMS code (RVSnowbird)
  • They all use some type of compression fitting for the transition, but PEX requires a crimp collar and a specialized tool to apply it
    Pictures would be helpful. That way Mr. Biscuit won't wear a hole in his head....lol
  • WH has plumbing holes with 1/2" pipe thread.
    Going from there different TC builders use different materials.
    Copper usually have flare fitting. Plastic pipes, compress washers.
    If you are not familiar how to deal with it, better call professional.
    Small crack on the tubing in hard to access space can turn pretty costly mistake.
    thanks
    :H
    Description
    What is it attached to?
