tlhathaway's avatar
tlhathaway
Solved
Water Heater Leak on start up.
The 12 gallon Suburban Water Heater in my 2024 Arctic Fox, leaks through the pressure relief valve during the initial heat up. I have been relieving the issue by opening the hot water faucet. This on...
  • opnspaces's avatar
    Aug 01, 2025
    I would say not normal but also not something I personally would worry too much about.
    If it's been a while since you've drained the tank you can letting it cool and then pull the drain plug. Let it drain then put the plug back in and run a hot faucet to fill it back up. The idea is to restore the air gap at the top of the tank.
