Old-Biscuit
May 22, 2016Explorer III
Drain hole is 1/2" NPT threads...........plug is High Temp Nylon also NPT threads
(NPT.....National Pipe Threads=====tapered)
Use a short brass pipe nipple (/2" NPT) to clean/chase the drain hole threads
THis will remove any crud between threads, straighten threads and clean them up
Then install NEW plug using fingers then snug up with a socket/long extension.
And just snug after finger tight....remember drain hole & plug are tampered
