bob213
May 23, 2016Explorer
GrandpaKip wrote:
I replaced the plug with a butterfly valve on my previous camper. No more problems.
Can't really get the crud out thru a butterfly valve plus unless it's copper(Brass?) you may have a problem with galvanic corrosion sealing it in place forever. (Two different metals corrode when water passes over them). Atwood also uses the nylon so you destroy the threads on the plug rather than the tank.
