freddmc
Sep 04, 2016Explorer
Water in Fuel
A friend recently had a situation where water in fuel destroyed his injector pump in his 2008 Ford F350. He said there was no warning that he had water in the fuel. How can one check to make sure thi...
agesilaus wrote:Kafn8td wrote:
Most modern diesels have a water separator in the fuel line. I think Ford recommends it be drained monthly, not sure about Dodge.
A lot of people check that filter by draining a little every time they fill up. The filter is under the truck, right underneath the driver's seat so you can check it without crawling under the vehicle.
Also that filter needs to be changed every second oil change.
