Abbydaddy72's avatar
Abbydaddy72
Water issue
While prepping my camper for a boondocking trip, I put water in the holding tank to test my pump. Water pressure was really low and water was spewing out of the city water connector. Any idea what causes this?
  • mbopp wrote:
    You can try depressing and releasing the check ball in the city water connector also.
    the first thing to try.
    bumpy
  • enblethen wrote:
    Check valve is stuck either by debris or spring is broken.
    You could use a hose plug to stop it until you can replace the check valve.
    May be the cheapest and quickest fix.
  • Wow! thanks for the quick replies!
    I will look at the check valve and roll from there.
  • Check valve is stuck either by debris or spring is broken.
  • Plug the city water connection and check it. How long are you running it you may need to let it fill the water heater before you get more pressure.
  • Check valve on the city water connection? Anything else, we'll need more details on your camper.
