bruse001ExplorerApr 07, 2015Water leakIm finally set up and of course I bought the trailer in Kansas and I'm set up in Texas . The lines under the sink are leaking pretty bad what's the best way to replace them it seems to be at the fitti...Show More
djsamuelNomadApr 08, 2015Make sure the fittings aren't loose. When my trailer was new, I had a leak and all I needed to do was tighten up the fitting.
Related ContentWater pump?Water Heater Leak on start up.Why no hot water?Nautilus P1 has leaking connectionsWater leak
