aja458's avatar
aja458
water line crimper
I need to replace the fitting on my waterline going to my toilet. is there a crimpimg tool I can buy to attach a new fitting to the line or can I just use hose clamps? thanks
  • All I can say is I had a plumbing issue last week and reached out to the forum. Taking their advice, I used a "Sharkbite". It took me one minute and no leaks. May be an option
  • Some hardware places 'rent/loan' tools.....you would need a PEX crimp tool
    NO.....hose clamp will NOT work on PEX pipe
    Sharkbite (Home Depot) Gatorbite (Lowes) has fittings that just snap on
    You cut the crimp off/make sure end of PEX has a straight cut/no burrs and then just push fitting on.
    Now would be a good time to install a shut-off valve so toilet can be isolated without having to secure all water to rig.
  • There is a crimper and crimp rings, made for this purpose. However, it would be cheaper to buy a push fitting (sharkbite), cut the tube and push it on.
    The fittings are available at Home Depot, Lowes, Menards, plumbing supply stores, and most hardware stores.
