BlayExplorerSep 18, 2020Water linesWhen blowing out water lines with a compressor what’s the secret to keeping constant regulated pressure thank you
CavemanCharlieExplorer IIISep 23, 2020Sjm9911 wrote:Bypass the water heater, or you will need a lot of air.Not if you drain it first. That is what I do and then use air to blow out the rest.
