seaweed2's avatar
seaweed2
water pressure
I have a 2016, 24ft Open Range Lite. The water pressure is the barely a steady stream. At home I hooked up without regulator and made no difference from using a 45psi. I traced all the lines, all handles are positioned correctly, no blockages.. I'm stumped. We have had class A, class c, other tt's and tent trailer, never had this problem. I haven't talked to factory yet, seeking thoughts of professional campers first. Semper Fi, Jim
  • Paul G. wrote:
    You should also check the screens at the faucets, they easily clog, especially the first time for the season.
    Paul...
    Yep, very true for new units. Had to clean all the screens a couple of times when we took delivery.
  • You should also check the screens at the faucets, they easily clog, especially the first time for the season.
    Paul...
  • Ok, thanks, pressure is same all outlets pump and city water so i'll start between pump and water in connections and see what's up. Just purchased in Sept. only been out twice so a clog seemed unlikely but.....
  • If you get the same results with hot cold, pump city water, at all outlets, then I would guess something is wrong between the pump and city water tee, and the hot water and cold water tee.
  • Same low pressure if using pump?
    Did you check/clean 'screen/washer' in city water hose connection?
    Could be check valve in city water' inlet assembly failing....restricting flow.
    And IF you have same low pressure using pump........do you have a WHOLE House filter.........clogged up?
    Is low pressure/flow at all faucets/shower/toilets?
    Dirty aerators at faucets...plugged water valve for toilet?
    Process of elimination......one item at a time
