I am just about to put the camper back together but wanted to check for water line leaks and low and behold the dang pump wont work. It sounds good and when I took it apart nothing looks worn out or ...
Mine has a 10" hose from the tank to the pump and then a 10" hose T'd in to the cold water line out of the pump, nothing fancy so the pump part has to be bad. I am on board with replacing it all but still don't have an answer on whether to buy a different pump or just go with oem.
