Me_Again
Aug 24, 2018Explorer III
Old-Biscuit wrote:
How do you normally fill fresh water tank?
Gravity fill port or a 'valve/switch' you turn to FILL
Gravity port...then pump internal check valve is not closing and allowing backflow thru pump when using city water. Typically you run pump/flow water thru pump and clear the debris etc BUT you use pump frequently so probably need to replace internal check valve in pump
'Fill' valve/switch...
Leaking thru/bad o-ring --bad valve
OR pump internal check valve
Anderson valves a noted to have O-ring issues if switched between settings with pressure applied to the water system. The core is easy to change with you get a replacement.
Chris
44,066 PostsLatest Activity: May 16, 2026
