NinerBikes wrote:
HMS Beagle wrote:
AnEv942 wrote:
Dirtpig wrote:
Wouldn't this idea be similar to running your stove burner on low? ....
No, The wave heater is a catalytic heater.
But, the heat output (and combustion byproducts) are pretty much identical.
But the scale of byproduct CO is much, much lower with the Wave 6 versus burning an open flame, and the efficiency is much higher. Hence the crack a window and crack a vent.
I would agree the CO is higher, though not much, much higher if the stove burner is working properly. The efficiency is about the same: no more heat is produced by catalytic combustion than open flame combustion.
