DutchmenSport
Aug 05, 2016Explorer
I suggest you use the WD system and just don't assume you don't need it. Better to have it. You're on the right track. Go with your plan and be safe!
Sounds like you purchased your truck used, in which case it makes sense the sleeve is missing. I would not advise using the sleeve that you purchased if it says do not use with WD. Go to your local Ford Dealership and buy the correct one. You will need it again in the future, guarantee it!
