Geno92308
Dec 09, 2015Explorer
I have this setup. It works fine and I did add a friction style sway device.
I did have an issue with a spring rivet backing out. This spring engages the piin when the bars are inserted. There is a kit you can order to replace the rivet, spring and pin. Must be a common problem if curt sells this as a kit.
To repair or insure this doesn't happen again, I installed a hose clamp over the Rivet.
