evanvalk's avatar
evanvalk
W/D HITCH W/SWAY BAR
I have a DW Hitch with a Sway Bar, Instructions states that you can not Back up with the Sway bar Attached, Any Body Know why, Thank you. Ed
  • My father-in-law sheared the sway bar's hitch ball off when he got the TT at an extreme angle while backing. As TomG2 said, if you're confident you're not going to turn that far, it will be fine to leave it attached.
  • I have heard/seen that warning before. The only thing bad that could happen is with the extreme angles sometimes encountered when backing, a bar might come out of the friction pad or get stuck there and bent when straightening out. Do a simple test to see if you can duplicate that condition. Otherwise, join the majority of us who disregard that warning.
