rbpru
Jan 16, 2015Explorer II
The WD hitch is intended to shift the trailer tongue weight from the rear wheel to the front wheels and trailer. This levels the load and improves TV steering and breaking.
Jacking up the bars to shift more weight to the front axle make little sense as you are now reducing the rear wheel load.
Put simply, adding the TT tongue weight to the TV causes it to sag. The WD hitch uses the bar tension to remove the sag by shifting some of the tongue weight back to the front wheels and the TT. The TV is level, the TT is level, the tongue weight has been more evenly distributed. The WD hitch is doing its job.
There is nothing mysterious here.
44,072 PostsLatest Activity: Aug 23, 2026
