hawkeye-08
Jan 22, 2015Nomad
If you want to keep your trailer and insist on towing with the MB diesel, you will be over the factory hitch ratings. If you reduce tongue weight to 600lbs or less, you will likely have sway due to not enough TW.
If you upgrade your hitch to aftermarket that is rated for 900lbs, then you will be close to that rating. Doesn't mean it will tow without issues. You will need to have everything properly setup to have the best chance.
IMHO, you will be over or near the limits towing your trailer with the MB diesel. Don't forget to purchase towing mirrors.
44,071 PostsLatest Activity: Aug 16, 2026
