the_bear_II
Feb 12, 2015Explorer
With the proper hitch setup and tow vehicle, weight is a non-issue when it comes to towing stability. In addition, you shouldn't have sway unless some outside force creates it (wind, passing semi, uneven pavement). So the hitch setup is important along with the right capacity tow vehicle.
The extra 4 feet will be noticeable when maneuvering especially in tight situations.
If towing with the same truck you will notice a slight drop in MPG (maybe less than 1 MPG) and slower hill climbing speeds with the 2000 lb heavier trailer vs the lighter trailer.
My advice is to choose the trailer that fits your lifestyle and then buy a truck that has way more capacity to tow it. Plus get a good hitch setup. You'll have years of comfortable and safe towing. Don't skimp now if you have the opportunity..."go for the gusto"
