we have a 2015 Ram 3500 tradesman addition dually 4x4 crew cab long bed. Cummins, Aisin trans. Torqlift steel tie down system. GVWR is 14,000 lbs. following info from Ram Body builders guide: em...
^ Holy cripes, you're loaded for bear! If you're running around with 11klbs on an AAM 11.8 axle, I feel even better with the 8klbs I'm packing around on the 11.5! Nice setup btw!
