towpro
Sep 21, 2016Explorer
weight advice
we have a 2015 Ram 3500 tradesman addition dually 4x4 crew cab long bed. Cummins, Aisin trans. Torqlift steel tie down system. GVWR is 14,000 lbs. following info from Ram Body builders guide: em...
towpro wrote:
not sure. I only have weights as posted by truck camper mag.
Dry: 3605 including fox value pack (plus I have dual pane glass and slide topper)
Wet: dry weight, 3,605 pounds + 53 gallons fresh, 442 pounds + 6 gallon full hot water heater, 50 pounds + 2x 30-pound full propane tanks, 54 pounds + 2 batteries, 130 pounds + stuff, 500 pounds = 4,781
I had everything on the "wet" list accept maybe 500 lbs of "stuff". I had all the pots, pans, dishes, silverware, etc, but no food coming home.
we ran out of food. We even had to call out for pizza delivery one night and they brought it to the dealers parking lot.
I will be out soon with trailer and BMW so I will try to find a scale.
Or maybe not. if its sitting right without suspension mods, do I really want to know :).
