towproExplorerSep 21, 2016weight advicewe have a 2015 Ram 3500 tradesman addition dually 4x4 crew cab long bed. Cummins, Aisin trans. Torqlift steel tie down system. GVWR is 14,000 lbs. following info from Ram Body builders guide: em...Show More
towproExplorerOct 14, 2016actual it adds up to 13980. 20 lbs under 14,000 lbs GVWR:). 1090 lbs below rear GAWR.680 lbs below front GAWR.
Related ContentDry tongue weight versus fully loadedWeight advice?towing near max weight. advice?Looking for camper weight advice!Tire Advice
