I have a 2005 Silverado K1500 with a 5.3 v8 and 4.1 axle ratio. Manufacturer book says max tow weight is 8600 lbs. I want to buy a travel trailer...preferably 26ft. What approximate "dry" weight ...
Keep the trailer GVWR inside the tow rating for best results. And if you are close to the max do not expect to carry much in the bed of the truck. I agree with the 'forget dry weight' unless you are planning to haul empty trailers for a living.
