Wishbone51
Apr 03, 2015Explorer
Once I get the tongue on the ball, I lower the jack more to lift the truck suspension a bit. The angle allows you to hook a lower link on the WD bars easier, then set it down. I used to really struggle before I found that tip. If your bars aren't level, then the hitch needs to be adjusted a bit.
I also have the Firestone RideRite air springs. Not needed to be level, but I get a bit of bounce (vertical sway :) ) without them. A couple extra pounds in them tightens up the suspension and makes for a really nice tow.
44,071 PostsLatest Activity: Aug 16, 2026
