temccarthy1 wrote:
If it is an Equalizer WD hitch, do NOT grease the bars where they sit on the L brackets. That is meant to be a friction point to stop the sway. If you lubricate, you will nullify the anti sway feature. I cannot speak for other brands that use the chains as I do not know the technical part of how those work.
This is an incorrect statement. I have used an Equalizer for many years now and I lube both the socket heads and the L bracket face. I do this because that is what the manufacturer suggests. They do say to lube it lightly and they even have designed a plastic sleeve to fit over the L bracket. I know that it is counter intuitive and that is why I checked with the Equalizer people. A little lubrication is not going to cause a problem.
