DR1VENbyCAMPING's avatar
Oct 09, 2017
Weight distribution hitch question
I just bought a Passport 153ML....my 2013 Honda ridgeline states "We don't recommend using a weight distribution hitch"
max towing is 5000lbs
hitch weight with all my passengers is rated for 550-600lbs
trailer is single axle(4500 GVWR)
hitch weight states 395
Any advice out there for this?
My concerns are the possibility of frame bending with a weight distribution on a uni-body frame the Honda has Vs. this floor plan with primarily a front area with all the storage...there's very little storage areas in the rear.
Wont that really add to a big increase in hitch weight and make the steering in the Honda squirrely without weight distribution?
I want to do all I can to protect my 2yr old that will be going with us.....
thanks all....
  • Honda knows best, I would follow their recommendation. I would not want to tow far or at high speeds without a weight distribution list.
    Keep in mind the weights listed are as they come from the factory. Once you add your camping gear and clothes, etc., you will most likely find your true weights are higher.
    Make sure you also check the weight limit of the trailer's axle. There is a good chance that single axle is already at its limit.
    -Michael
