Danford50's avatar
Danford50
weight distribution
Looking at a travel trailer 20 ft long dry weight 2400 lbs do I need a weight distribution system according to the sale person I would not need one but a sway bar hook up.
  • If it was me, I would get the weight distribution bars.
    Jack L
  • You could add a Friction Sway Bar...just have to remove when backing sharp turns, etc. We had one for our pop up. Helps when the big rigs pass you up.
  • If it does not tow right, fix what is wrong. No WD hitch needed with that setup.
  • Ivylog's avatar
    Ivylog
    Explorer III
    NO WD and with enough tongue weight no sway either.
  • As long as you load it properly to keep the tongue weight up, you shouldn't need WD or sway control with that combo. If the trailer is loaded tail heavy to keep tongue weight down, sway control won't help. Air all tires to sidewall max while towing. Just my humble opinion.
  • it is called r pod made by forest river and I will be towing with a 2015 f150 2.7. v6
    What 20' TT only weighs 2400 lbs? We used to have a 20 footer that weighed 5K lbs all loaded up. If that's a factory dry wt. figure, it's going to weigh a fair bit more when fully loaded for a camping trip. Use it's GVWR wt. and take 12-13 percent of that to estimate the tongue wt. Then determine the payload capacity of the tow vehicle to check that the tongue wt. is within it's payload capacity. Depending on what the TV is (small SUV to 1 ton pickup) you may or may not need a WDH. Even if you *might* get away without one, it could be a good idea so you can have sway control (integral or friction bars).
  • That all depends on your tow vehicle however it will always tow better with one. If you have a 3/4 ton truck then you probably do not need one but if you have a minivan with a 3500 pound tow limit then it is definitely needed.
