schlep1967 wrote:
4x4ord wrote:
bluefishgary wrote:
Yes the scale I had to weight the
Truck with trailer hooked up
Its really simple math guys
Truck subtracts the steering axle
Weight from drive .The scale is 60 ft
Long.
So ... are you seeing where you screwed up with your simple math?:)
I thought what I did up top was simple math. You guys must be doing that new math....
Well you wrote: "Truck and trailer weighs Steering axle. 5360 lbs. Drive axle 13,400
Trailer axles 10,640 lbs. Pin weight 4,000 lbs."
I believe you got your steering axle right.................................................... 5,360 lbs
I'm guessing you should have said your drive axle weighed ..................... 8,040 lbs
I'm going to trust that the sum of your trailer axles was as you stated .... 10,640 lbs
and I think you should have stated your pin weight to be .......................... 4,200 lbs
Anyway go ahead and post a picture of your car .... and wife along with applicable weights and measurements.:)
