jamminalong wrote:
Yep! But I didn't want a monster on my back. Where's your cert.? I'd like to see it.
I stop at closed State Patrol truck scales, so no weigh slips. From what I remember of my last stops:
Unloaded truck (no driver):
Front - 4500 lbs
Rear - 3000 lbs
Loaded truck + TC (gear, food, fluids, occupants):
Front - 5000 lbs
Rear - 6750 lbs
Loaded truck + TC + enclosed trailer w/WDH:
Front - 5250 lbs
Rear - 7000 lbs
Trailer - 7000 lbs
Truck specifications as shipped:
2005 F250 SuperCab, short bed, 40" CA
Front axle: 7350lb manual 35-spline Dana 60, Warn manual hubs
Rear axle: 3.73 LSD 9750lb 35-spline 10.5 Sterling
Wheels: 245/75R17 3050lb tires on 17x7J 3100lb rims
Door tag: 5600lb FAWR, 6100lb RAWR, 9800lb GVWR, 23,000lb GCWR
Towing: 12,500lb conventional, 15,600lb fifth wheel
Maximum 2005 SRW specifications with OEM wheel and spring upgrades:
Wheels: 275/70R18 3640lb tires on 18x8J 3590lb rims
Snow Plow Package: 6000lb front spring rate
Door tag: 6000lb FAWR, 7000lb RAWR, 11,500lb GVWR, 23,000lb GCWR
Current specifications with upgrades:
Wheels: 245/70R19.5 4805lb tires on 19.5x7.5 4500lb rims
Suspension: Upper StableLoad stops, Lower StableLoad wedges, Firestone airbags, Rancho RS9000 shocks
Ratings: 7350lb FAWR, 9000lb RAWR, 16,350lb GVWR (FAWR+RAWR), 23,000lb GCWR
