noteven's avatar
noteven
Explorer III
Aug 24, 2017
Weight ratings on light duty trucks
Take a look at the weight rating sticker on your vehicle.
Can anyone explain why light duty trucks (as opposed to medium duty Class 5,6,7 and heavy duty trucks Class 8) have axle weight ratings (GAWR's) that add up to more than the Gross Vehicle Weight Rating - (GVWR)?
How would you achieve GAWR on the rear while staying under GVWR of vehicle?
    Place the payload on the rear bumper such as a travel trailer.
    How about post your actual numbers and scale weight of each axle.
    Then you will get some real answers.
    Weight ratings are what they are. Depending on what you are doing ANY of the ratings may put you over even if you are within the other ratings. Ratings do not necessarily "add up" to the total.
  • I think the answer is also in part because the manufacturers are sourcing axles from suppliers and that means taking what is on the shelf and adapting it the application. To maximize production volumes they design axles to cover a range of vehicles. The vehicle manufacturer on the other hand may be specifically targeting a particular class of truck "light duty", "medium duty", "heavy duty", etc... They go to the parts bin and grab the axle that best accommodates their design criteria. Just because the axles they grabbed might take more weight doesn't mean they will. The vehicle manufacturer may choose not to take advantage of it because it might require larger brakes, beefier frames, and larger engine to pull all that extra weight around to fully utilize the ratings on the axles.
    I should preface the above with I know nothing about the industry and for all I know, the real answer could be something to do with fairies riding unicorns...
  • Sticker GAWR is how much of the GVWR can be seen by each axle, but combined total cant exceed GVW. Mine total of axle ratings about 2000# more than truck GVWR, but each axle is rated less than overall- if rear was maxed (to sticker number) would be under GVWR?
  • PARTS are MORE then the SUM.........
    You can NOT load up so weight is placed equally across both axles.
    GVWR is MORE then JUST axle ratings...it includes FRAME, SUSPENSION and TIRES
    My 3500
    FAWR----5200#
    RAWR----6200#
    BUT....GVWR is 10100# (not 11,400 sum of axles)
  • My Nissan Titan XD Diesel has 4,900 lbs per axle (=9,800 lbs) but the GVWR is only 8,800 lbs on the sticker.
  • GAWR of Front+Rear isn't that far off from GVWR for my truck. The axle rating is a different number, and I think usually higher. So, a heavy load could exceed the GAWR for the rear and be under the axle rating.
