mlayton's avatar
mlayton
Weights - why different reported numbers for the UVW??
I am so confused about the variation of these reported weights. We are looking to purchase our first TT (as some may have seen from my other post). We have a Ford Expedition EL which has a tongue weight of 890#. We prefer to stay at the conservative end of our weight capacity of loaded 5930-6850 (based on the 13-15%). This puts at an ideal loaded weight of 5930#.
Here is the issue, we are seeing ranges for your "stuff" advising to allow 500# to, on this forum advising more like 1000# (quite a range). In addition, I simply do not understand when I look up a model, like the Lance 2185 and it says the UVW is 3930#, and then I see 2 dealer videos quoting 4250 & 4300#. I don't understand the variation??? I'm seeing this all the time - the Surveyor 291 quotes a uvw of 4423# and then the dealer you tube video quotes the same model at 5300# - now a unit we would not consider. With trying to get a queen and 2 bunks for kids, many models hover in a close range for us on weights so to have numbers just 300-800# in some cases seems like a lot. How do we even narrow it down when weights jump like this? Are they adding stuff?
Now, second question is: is it even necessary for us to try to stay to that more conservative weight number or are we truly OK as long as we land in that 13-15% range? What happens if we push towards to higher number but do not exceed it??? Is the handling just******or is it actually dangerous or painfully slow to get anywhere?
  • The UVW listed in brochures is for standard items on the TT. After extra items are added like an elec awning, changes in furniture etc, then the TT is weighed at the factory and a sticker is placed on the door. That sticker is the official UVW of the unit. That's why the ones in the video are heavier than the ones in the brochure. Options that are listed in the brochure changed the weight. If you know what you add for gear then you can safely add that weight to the TT's sticker weight and you will be close to your camping weight. However if you have never camped in an RV before then you will have know idea what you will need. IMO adding 1,000lbs to the stickered weight is safe. If you add less then fine, but chances are you won't add all that much more. If your that close on weight that 500lbs makes or breaks it then you need to down size the TT or upgrade the TV. You don't want to be in a situation where you can't take the things you want to because your over weight in the TT or the tow vehicle.
  • Your question and observation is exactly why most people (including me) don't even look at UVW. It means nothing in the style TT you are looking for. With the wieght limits and style TT you are looking for the Cargo Carrying Capacity (CCC) of the trailer is going to be pretty low any way.
    Look for a TT with a GVWR of around 6,000# (don't worry about a couple hundred pounds over) and a CCC of say at least 750# if your talking about vacations and not extended trips.
