RoyB
Mar 25, 2016Explorer III
As stated above you only have 120VAC wired around the circuit breakers. The 12VDC Power will be wired around the ATC FUSES...
Apparently this circuit breaker is providing 120VAC to the Microwave unit AND the Converter/charger unit using two poles. Both of these units require 120VAC to operate..
If you have the word DC POWER written into the label a better word would be CONVERTER... The Converter takes 120VAC and converters it to 12VDC to run all of our 12V devices when connected to Shore Power. It also charges your battery bank during this time. Both the Converter DC Output and the Battery Output Terminals are connected to the same point of the on the 12VDC Power Distribution Center...
This is a simplified 30A Electrical Block Diagram for the RV system
In my WFCO 8900 Series Distribution Center I have five full slots for circuit breakers. The 30A MAIN circuit breaker is a physical full size. The physical full size Circuit Breaker housing will handle the heat generated better than a physical half size breaker will. This is why you want the main 30AMP breaker to be a physical full size...
The remaining four slots in my case all have physical half size (One Pole) breakers installed and this gives me a total of eight possible separate circuits I can control. You can also install a physical full size circuit breaker that has two poles breakers built-in and accomplish the same thing of controlling a total of different circuits..
The physical full and half size of the breaker physical has nothing to do with the rated switch.
You can find the exact circuit breakers being used at LOWES in their electrical section..
Circuit breakers are easy to install and need no tools except to connected the cable...
This is an simplified drawing how to install a circuit breaker. Place against rail and then push down onto raised busbar. It is best to connect the wiring first... Be sure the 120VAC has been removed from the busbar before installing the circuit breaker (Turn OFF Main 30A Breaker).
My attempt at explaining it haha...
Roy Ken
Roy Ken
